Author Topic: Master Repulsion in poe2 with U4GM Tips  (Read 447 times)
Offline Hartmann846
« on: 06.06.2026, 12:42:15 »
Repulsion is one of those PoE 2 gems that looks simple, then makes you re-read the tooltip twice. It spends Ward, not Mana, and it rewards players who plan hits after the curse lands, much like budgeting PoE2 Currency before a messy build swap.
What Changed With Repulsion
Patch 0.5.0 pushed Repulsion into the Kalguuran skill pool, and yeah, it feels different from a normal spell. You place the curse, wait through the delay, then hits on cursed enemies pop Repulsion Wave. No follow-up hit means no real payoff.
The big trap is the tag soup. Spell, Attack, AoE, Curse, Trigger, Physical. Sounds like everything scales it, right? Not quite. The cast itself deals no damage, while the triggered wave has its own physical base damage and doesn't lean on your weapon.
Core Numbers Worth Remembering
    Ward Cost: 15 Ward at gem level 1, climbing to 116 Ward at level 20, so spamming it without Runic Ward gear feels rough fast.
    Detonation Window: 1.5 second curse delay, 6 to 7.4 second curse duration, 0.50 second Repulsion Wave cooldown with 5 stored uses.
Reality check: If you cast Repulsion and just admire the rune, you've basically paid Ward for a fancy circle.
Why Stun Players Care
Repulsion applies 20 Fragility, and Repulsion Wave gains more stun buildup per Fragility on the target. That's the scary part. Add the 200% increased knockback distance, and packs start moving around like someone kicked the whole screen sideways.
    The buzz on Discord: Players like the control, but nobody fully agrees on the cleanest stun formula yet, especially with quality and outside modifiers stacked together.
Build Checks Before You Commit
     Red Flag: Don't scale weapon DPS and expect Repulsion Wave to suddenly behave like a proper weapon attack, because it uses its own base damage.
Where I'd Use It
Repulsion makes the most sense in dense mapping, stun setups, or curse-heavy trigger builds that can keep Ward flowing. Low-level gems also have enemy-level curse caps, so don't ignore gem upgrades. If you're testing it seriously, save your path of exile2 currency for Ward gear first, then tune damage later.
